hear goes then,
engine:
std balanced and knife edged crank
Billet steel con-rod's
87mm Omega forged pistons
ported n polished head
steel head gasket (unkown mm)
titanium valve retainers
jun valve guides
jun valve springs
kent 280deg cam's
proper wrc spec steel head studs
wrc spec steel main bolts
steel rod bolts
sard 700cc injectors
19 row mocal oil cooler
2 cossie intercoolers welded together, possibly the shortest i/c pipe run on a 'R' ever.
std fuel pump supplying a swirl pot then a big bosch pump
hybrid skyline turbo (unknown spec)
advan manifold
3inch straight through exhaust
trans:
AP racing paddle clutch
lightweight flywheel (unknown make)
quaife gear kit
Chassis:
tein coilover's
full whiteline kit (with the front and rear anti roll bar's)
carbon prop shaft
carbon driveshafts coming soon
AP 6 pots up front (unknown disc size)
AP 2 pots rear (unknown disc size)
15" OZ chronos or leggeras
all perspex windows
carbon bonnet
plastic boot lid
completely stripped interior
one cobra seat
full roll cage
carbon fibre door cards
the car was running a std ecu with a super afr and a greddy avcr hes in the middle of fitting Motec M8 at the moment with a Motec digi dash,
i've missed loads off this list but i cant remember everything its got coz just about nothing has been left std, its done him 2 seasons of hard track racing without the slightest problem, apart from a fuel pipe splitting. where i've put unknown its just coz i cant remember, not that he doesnt know.
