Brake bias valve
Trip
Has anyone ever put one of these on the R ? I have removed the ABS from car by bypassing the actuator and would like to have some sort of control over front and rear.
The problem i am seeing is that all 4 wheels (brakes) work independently. How on earth can a bias valve be installed ?
I would assume it would be the same problem if one tried to install a hydraulic type hand brake on the R
williams
should be the same as how i fitted 1 to my other car, saxo vts :oops:
it had 2 pipes from MC to ABS unit. i just junked the ABS unit. the 1 of the pipes i T-pieced to each from caliper. the the other pipe i ran to the bias valve, the from the bias valve to another T-piece which then went to each caliper.
to fit a hydro handbrake you will just T-piece it in after your bias valve but before the last T-piece.
stumo
The AP bias valve on the right is twin bore, it has two inlets and two outlets. It won't be cheap but it will work.
