bottom ball joint
Aaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhh the thread on the ball joint is knackered and can't tighten the nut, is it possible to just replace the ball joint or is it a whole new wishbone? Or anyone got any other ideas of what I can do??? HELP!!!
Shaun
:D You can replace the ball joint :!: Seperate the ball joint from the hub,then if you look below the rubber boot you should find a circlip,remove this and chock the lower arm with blocks of wood to support it,make sure the wood is away from the bottom of the ball joint,give the ball joint a few wacks with a hammer to remove it :!:
