Mad
I was doing some research on turbo's and found the following link -
http://forums.nasioc.com/forums/showthread.php?t=2135597
Although a very long thread, it is some really interesting reading about the Borg Warner EFR 7670 vs GT3076R / GTX3076R / GT3582R and others.
The Borg is just over 3" longer in body than the GTX3076R
Article conculsions below -
So it looks like there is a decent solution between the GT30 and GT35.
Any takers???
On the Dyno Conclusions
The EFR7670 is a turbo that I personally feel compares more like A GT3582R, but spools faster on
the dyno (like a GT or GTX3582R w/.63Ar). Comparing the EFR7670 to a GTX3076,
its slightly laggier, but that lag is a trade off for more power. Since the
GTX3076R and EFR7670 have very similar compressor maps, the HP gained is do to
the higher flowing turbine housing/wheel. Since the dyno is very controlled, and
a high loaded run, in all these tests the super light Titanium Aluminide turbine
wheel doesn't come into play at all. What this does show is the turbine wheel
and compressor wheel design is a notch up over the Garrett GTX stuff. From what
I have seen Borg Warner has designed a turbo that does what they say it should.
It makes more power and spools faster than the GT3582R.
On the Road Conclusions
My conclusions are this. The
dyno conclusions do not match what I "feel" on the road. On the road, I feel
like this is much more lively than the GT or GTX3076R. Its interesting as in
some road tests the EFR7670 shows the same spool up RPM as the GTX3076 w.82ar,
but it feels so much snappier between shifts light load low RPM shifts. Meaning
the normal day to day 2000-4000RPM shifting is about 50% better than it was
before. In some logs I notice that the GTX would show say 2-3psi of boost at
these really low RPM's, where the EFR is showing about 5psi. Its only a couple
PSI but that makes huge difference in how it feels. You can see this on the dyno
graphs where the EFR is making more TQ at 2000-2500.
Under full throttle high RPM acceleration, again the car feels a bit faster. It feels like Its right
back on the power. When comparing this to the GTX3582R graphs I have, it blows
it out of the water. When comparing it to the GTX3076, its very close in respool
time, but there is this thing that just "feels" better.
Final Conclusions
I used to think that there are lots of turbos out there, depending on the size of the
turbine, its going to spool at a particular RPM, depending on the compressor
wheel used, your redline and boost, its going to make a given HP. So then it was
a matter of what size wheels Garrett and others used to create a given turbo and
it was a balancing act of spool and HP. But Borg Warner has proven that there is
some magic left in its turbos in that it actually spools faster than its
comparable GTX/GT3582R turbo and makes almost the same power, if not more on the
GT3582R.
Any takers???
