Best wideband lambda?
ChrisS
I have a innovate lc1. blew my first one as pparantly the are very sensitive to signel from the distributor which i fond out after fitting right next to it. replacement has been fine mounted elsewhere although i havent used the data logging ect
GTI R RA
Perhaps I will try Innovate if it works plug and play without data logging and such.
Both kits costs the same.
I have an a pillar pod for two gauges and I found a boost gauge with the same style as Innovate.
olliecast
I use innovate. Interacts directly with nistune. Only had to change a sensor due to me twisting the wire.
Definately reccomend it
