Banging when cornering slowly
Just wondered what you think this problem might be. When I corner slowly, only on right hand bends (like roundabouts), my rear passenger side wheel makes a banging noise. Sounds exactly the same as if the wheel nuts were loose, but they're tightened fully.
Any ideas?
Ben
MR Cruise 2003 III
December 20th
Donington Park
Nah, I would of noticed if I ran anyone over.
MR Cruise 2003 III
December 20th
Donington Park
i've had this problem before mate, turned out to be a knackered bush on the wishbone, could well be the same thing.[:)]
nickg123
This is EXACTLY what i get - when turning Left, sounds like my rear right wheel is doing it!
I thought it could be the CV joint??
Anyone know a good way of finding out what the problem is though?
www.anythingcars.net - Make All Your Pulsars Dreams Come True [8D]
zia
the thing is if you don,t know what your looking at or for you probably miss it unless you have some experince.possbility of what it could be are endless
1 suspension not located
2 spring in leat loose
3 antiroll bar bushes worn
4 antiroll bar links
5 stub or sub frame bushes worn
6 drive shaft bearing worn
get some body who know how to check these item.i,d do it for you mate if you where anywhere near me
hope you find the solution
zia
lord of the "R"
