its just the oil that's different, R12 was CFC and ran on mineral oil, R134a is HFC and runs on synthetic. I use the term 'ran' loosely, the oil is for the compressor only and because it is within a sealed system along with the refrigerant it needs to be compatible. The R134a contains Fluorine, this is the fraction of the refrigerant that wont mix with the mineral oil.
In short, drain the oil, replace the drier, refill with ester oil, vac and charge. Ester oil is hygroscopic and should be replaced anyways if you got your hands on an r134a system from an almera.
Hoses etc are all compatible, R12 and R134a running very similar pressures. An R12 to R134a is a very straightforward retrofit and very common overseas
