you'll want to get it de-gassed at a shop!It's easy enough, I did it, so it must be.
Have a look here --> http://www.gtiroc.com/forums/showthread.php?t=32822
Only warning I give is, try not to inhale any gasses that might escape when removing pipework, I got a faceful and floated around the place in a daze for a few mins! :lol: :doh:
he`s got to try that!I heard if the older gas hit a hot manifold for example it would turn to Mustard gas?
I used to work as a refrigeration engineer 10 years ago, if you are going to let the gas out yourself make sure you do it an an open area and dont inhale it :doh: The gas is heavier than air so in high concentrations could suffocate you if it gets in your lungs ;-)Only warning I give is, try not to inhale any gasses that might escape when removing pipework, I got a faceful and floated around the place in a daze for a few mins! :lol: :doh:
Can't we line up all the dumbasses and get them to have a good lungfull or two.........I used to work as a refrigeration engineer 10 years ago, if you are going to let the gas out yourself make sure you do it an an open area and dont inhale it :doh: The gas is heavier than air so in high concentrations could suffocate you if it gets in your lungs ;-)
You'd need a big supply of gas ;-)Can't we line up all the dumbasses and get them to have a good lungfull or two.........![]()
