AFM Volts.
N
NEIL R
Hi all
Wonder if any body can help 2 wires touch on the AFM causing the car to run like a bag of spanners (over Fueling greatley)i have fault code 12 AFM circuit.
When plug C is conected it send back a 12v single causing the over fuel. we have tried a second AFM but still got the same readings.
Wondering if anybody else as had this and also if sombody could check there resistance with the car running.
Thanx for your help.
I had a similar problem last year. The car would run like a bag of crap, chuck out black smoke, and not rev over 3k. I was getting fault code 12 so i tried changing the airflow meter and checked all the wiring but it still didnt cure the problem :(
It turned out to be a blown track inside the ecu :wink:
