Actuator Question
  • Thread starter Leecarmichaeluk
  • Start date
L
Leecarmichaeluk
is the standard actuator on a pulsar adjustable the same as the subrau one ? I have noticed that there is thread on the arm on the end that attches to the wastegate, if it is then you can shorten the arm and make the actuator pull harder and this will make more boost
Adam L
yes, to shorten the rod your increasing the spring tension hence more pressure will need to be applied to open the wastgate
but the solenoid bleeds off the majority of the pressure does it not, the actuator itself is set to 3psi
