Dooie Pop Pop
the light came on when i moved the car and took it out for a shake down :?
i turned the ignition off and started the car again and the light stayed off
except a couple of times when i pressed the brake pedal lightly if felt like the abs was cutting in :shock: :? :roll:
when started again the light stayed off for a few secs and then came back on again, whilst the light was on the juddery abs sensation did not occur
brakes seemed ok before the engineoutscopy just a little low ( but not that low) so im guessing this could be a case of sensor contamination from rust off the disks or possibly oil.
not too sure what im looking for tbh
cheers, Stu
cheers, Stu
