what size lift has most people hks cams got
E
Edd
ooopss sorry :oops: :oops:
erm don't know then
i know Ginga's gone for quite a high lift, 12mm i think?
Nad
I think they come in 3 stages, Step 1,2 and 3 with lifts 10.5, 11.5 and 12mm respectivly with a choice of duration as follows
Step 1. 256-264 10.5
Step 2. 256-272 11.5 or 12
Step 3. 264-272 11.5 or 12
This information is based on the SR20DET specification and may not be specific to the RNN14 series.
Nad
GINGA
I've got the 264 step 2 ones with 12mm in/11.5mm ex lift they do come in 3 stages step one is 10.5/10mm iirc and step 3 is also 12mm/11.5mm i think which seems a bit odd so don't know how they differ from the step 2 ones :?: though hks do recommend uprated valve springs on step2,3 cams
nismoboy
I got my hks 264 cams from hiteq and ian told me they gave an 11.5mm lift and that they didn`t need uprated valve springs,so i take it that they are stage 2 cams? anyone know more about these?
J-GTi-R
Yeah yeah, everyone knows you've got Tomei cams Nad... :roll:
Sweeny
Do step 2's really need uprated valve springs.
And forgive me for being a bit dumb, but what difference does the lift make that the duration doesn't? Does it just move the power higher up the rev range? :oops: :?
James.
memski
Nad said:
No one makes a better or more aggresive cam than ***** :wink:
Nad
Tomei ones seem to have a high lift value, but peak lift doesn't necessarily mean they are the most aggressive :wink:
stuart rawlinson
264 11.5 Lex
Or we did think at first that HKS had sent out a funny pair But uncle Ian thinks there ok so thats fine
Stu
Nad
memski said:
Nad
No the fact that they are matched to a small duration does :wink:
Nad
My car is off the road now for another clutch and gearbox :roll: and it needs re shimming too so i reckon its the ideal time to fit a set of cams as well :D
As i'm not that clued up on profiles/lift/duration etc i need some advice on which ones to go for.
My car is pretty standard at the moment, only mods are a blitz sus filter, mongoose system, and hks 1.2 mm headgasket. As well as fitting cams i'm gonna fit an uprated fuel pump and take the boost up to 1 bar :D
I dont want to sacrifice too much low/midrange power/driveability and would like to gain some torque if thats possible :?: Also do you have to change valve springs :?:
Any preferances on vernier pulleys?
