Turbo Oil Feed Banjo Bolt - 7/16x24 UNF?
billy187
M12 x 1.25 is the correct size for the banjo into the block, I'm after the one that fits into the turbo itself.
7/16x24 is the correct thread, the length of the banjo bolt depends on the thickness of the banjo fitting on the oil feed as they can vary depending on who its made by. And the hole in the turbo isn't that deep so you just need to make sure the bolt dosen't bottom out.
billy187
Cheers thanks Mark, think il give Hose Solutions a ring as the oil feed is off them to see if they can help, if not guess the one in the link is worth a try.
billy187
Just to confirm for future reference, 7/16x24 is the correct thread for the turbo side and Hose Solutions were able to sort me out.
