Top mounting an oil cooler??
C
Crazy
Due to the pipe runs from my Forge intercooler I can not find a suitable place to front mount my 19 row oil cooler (19 row :shock: was supposed to be a 16 row but was sent a 19 row by mistake) So I am going to have to top mount my oil cooler :( (for now) :twisted:
What problems will this cause :?:
What are the good/bad points of doing this :?:
B
BOYYYDY
Hello mate, I had a 13 row cooler on top of mine when i first bought the car, I went through 3 of them in about 4 months! they just shake so much that they split. being an even deeper cooler than mine yours might get the same problem, not very nice pumping oil out over the engine :cry: Why not pick up 13 rower(they're really quite cheap, 30-50 quid) and put it in the front somewhere!
C
chrislloydus
you should isolate an oil cooler from vibration anyway by mounting it with rubber mounts (mocal sell these too). BUT i doubt they would be strong enough to reduce the vibration enough if the cooler is bolted to the engine.
Not possible to make up a mount off the strut brace (if you have one) ?
Other than that, put it behind one of the brake ducts :)
Chris
