Testing the Water
boucherie
First of all i want to make it clear that im in two minds to sell the car or break it for spares. This is to show people what the car has got, so if someone decides to buy it whole then great, if not then i will most likely start stripping it down towards the end of October.
I apologise in advance for the exhaustive list and if you have any negative comments about my prices or anything then either keep them to yourself or if you feel that strongly about it then PM me.
Far too many posts have been clogged up with spam and other c r a p in the past
About the car:
1991 H reg - shell in good overall condition, can post pics on request
Black
75k miles (speedo converted at 93400km, 4 years ago)
Tax 08/09
MOT 08/09
Engine made 379.7bhp @ 1.3Bar. (the new elbow and downpipe made 21bhp alone even on the previous map)
Original Flare
Original Umbrella
Original Nissan Pulsar Mats
Original Nissan Rear stereo system and parcel shelf
Original Spare wheel and cover
Stock front bumper trimmed to fit front mount intercooler whilst retaining OE look
Nissan Front and Rear Fog Light switches
Tinted rear side windows
Auto Illusions El Dials - Very Very Very Rare!
Custom 3 guage pod on top of dash housing Autogauge 'Blackout' EGT / Fuel Pressure / Boost gauges
Powerflex Front Bush Kit
Whiteline Anti lift kit, Rear Subframe Bush Kit, Rear Strut Brace, Rear ARB
OMP Front Strut Brace
Brake Stopper Bracket
Wind Deflectors
Clear Side Repeaters and front indiactors
Battery Relocated to Boot
Momo Cobra Gearknob
Outside Temperature Display located in centre console
TOAD MP3 Cat 1 Alarm and immobiliser
Additional Immobilisation device
Turbo timer, Razo pedals, Nismo Flat bottom steering wheel
Walbro Fuel Pump and fuel lines replaced
Uprated Track Rod Ends
Front Wheel Bearings changed summer 2007
Longer wheel studs fitted with spacers for alloy wheels
Motorsport Toweye fitted to front with toweye cover modded to suit
Performance Goodies:
Complete Engine - including all sensors, intake manifold, fuel rail, fuel regulator, spark plugs, leads, alternator, starter motor, air con pump. Runs great, no smoke, not using oil and maintains 4bar oil pressure on daily use.
Intake Manifold finished in blue and all the internals have been stripped down and cleaned thoroughly, includes fuel rail and hoses on the rear. can also supply 12mm T-pieces if the rear hose mod is to be required.
Stealth Shelf 36mm Thick finished in Black
16" White SSR alloys fitted with 195/45/16 tyres all with loads of tread on them, excellent condition
G-Force Coilovers with SBC Camber Bolts
NEW HKS Cam Pullies (still wrapped up)
SAMCO Radiator Hoses in red
NEW SAMCO Rear heater hoses in red (still wrapped up)
NEW SAMCO Oil cooler, Power Steering and Heater hoses in RED (still wrapped up)
NEW Goodridge Clutch Pipe
Apexi Power FC Pro with Commander (includes current map)
Apexi AVCR
Bucket Seats in Silver and Black on GTIR Subframes
800cc Venom Injectors
Nismo Adjustable Fuel Pressure Regulator
Poly Steering Rack Bushes
Poly Gear Shift Bushes
Shot Peened Gearbox with Ap organic Clutch (used on track with no problems, never launched)
NEW RPS Max PUK Clutch
Helix Organic Clutch 4k of use - VGC
310mm Wilwood 4pot discs and Pads. (new discs last year)
Grooved Rear discs with EBC Yellowstuff pads (fitted july 08)
Goodridge Braided Brake Lines
Z32 with plug wires into existing AFM wiring
GT3071r 0.86ar with 2.75" inlet with Braided lines and Oil Return Kit
Stainless Steel Manifold with hole for EGT probe
Front Mounted Intercooler and pipework
Carbon Fibre Spark Plug Cover
3" Custom Stainless Steel Elbow and downpipe with integral screamer. downpipe has bung welded in for wideband applications and mounts to a mongoose rear section with 3.5" exhaust tip. (exhaust is 100dB at 2/3rd revs so track friendly)
Front Mounted Mocal 16row Oil cooler with Thermostatic Plate
Nismo Front Bumer Guard
Spares:
Standard ECU
Standard Shocks and Springs (full set)
DET sensor
Propshaft
Pair of Wishbones
Alternator
Starter Motor
Nissan Grill
Clutch Slave Cylinder with Stainless braided pipe
Brake Master Cylinder
Front Slam Panel and Top radiator bushes
Rear wiper motor
sump pan
Mocal Thermostatic Plate
10 row oil cooler
Mongoose exhaust, modded to fit 200sx elbows but ive never tested that out
I will update with more parts as and when i find them as im sure there is alot more i havent mentioned.
If anyone is interested primarily in the car as a whole then please let me know, and depending on the interest in the next couple of weeks will decide which route i take.
Pricewise, let me know what you think and il get back to you but if your gona offer 3-4k then keep on dreaming!
jpward
First dibs!
"NEW SAMCO Oil cooler, Power Steering and Heater hoses in RED (still wrapped up)"
boucherie
also to add:
car was waxoiled 3 years ago fully underneath
rising sun decal on roof (easily removed using a hairdryer if not to your taste)
i can include the stereo (pioneer flip front cd player, 6 disc changer, pioneer 6*9 with banana plug fittings and infinity front speakers) depending on needs.
