Standard Fuel Pressure Regulator
Hi All
Having a really bad kink from the pipe on your standard fuel regulator could this cause the car to run on the lean side as when my local tuning garage checked the car seemed to be running rather lean throughout the rev range.
Any advice would be most appreciated.
David :D
oldaneal
Hi mines been on the rollers with the same problem. found that hose kinked on mine as well after and sorted it but not had it back on the rollers yet. seems to go a bit better thou. the only other sugesion would be to check the fuel filter as they cause probs
