Silicone hoses
johnsy
im after some silicone hoses,
63mm x 400mm minimum or 63mm 45deg elbow
76mm x 400mm minimum
and a 76mm elbow
thanks Dan
skiddusmarkus
Do you mean reducers?I can't think where you'd need a 40cm long peice for unless its for cutting up.
I get most of mine off ebay, just make sure they are 4 ply thick or so, their bursting pressure will be way beyond the boost you can run.
johnsy
im not 100% sure of the lenghts i need,
76mm if for the turbop inlet, and the 63mm is for the turbo to intercooler,
skiddusmarkus
I got my 76mm>71mm reducer for the turbo inlet from ebay for £8 I think, my 51mm>63mm for the outlet cost me £10.They are both around 3" long.
The tricky one for you I guess is the outlet as you don't know where the new outlet will be in relation to the old.You could keep your current intercooler silcones/rubbers and then use a 51mm>63mm reducer(I think thats what the standard size is but measure it)off the turbo and buy a length of 63mm stainless pipe and cut it suit and join to the intercooler silicone.
johnsy
the outlet of the md196 is 63mm and the inlet on the arc tmic is 63mm, there's no need for reducers
the maf to turbo size's are both 76mm
iv had a look on ebay
