shim sizes required
GTIR-LOZ
hello, i have checked the clearance on the camshafts etc and req the following:
shims
2.45, 2.60, 2.40x2
guides
2.40, 2.50, 2.42, 2.60
if anyone has these spare please can i have them:-D :thumbsup:
ard1ey
They only go up to 3.50mm thick dude, have you measured them just sitting on the table? The thicknesses are given from where they contact the valve and the rocker arm tip.
GTIR-LOZ
just measured the thickness of whole shim from bottom edge to top of shim think you just have to remove 3mm from this value so they should all start with 2:roll:
or as you have to measure them anyway to find out which sizes just measure from the bottom edge to the top:thumbsup:
