Running a little hot... Rad and Rad Fans...
Rishi
Still waiting on some shims!
Right... my fans aren't turning on...
Likely problems...??? Fan switch...??? Where to look...???
Also i noticed that my engine temp sits just below the red... its even done this when the water was cool/warm...
Oil temps and oil presures are all fine... no funny noises etc......
Ideas appreciated...
Rishi
I
Innovate Performance
you temp gauge sensor is not reading right.
Rishi
I did think it was that but i thought that if it was reading high that the fans would at least come on...?
Rishi
Rishi
GINGA said:
the gauge sensor is a seperate sensor from the ecu one and the ecu turns the fans on.
So whats the likely problem...???
Sensor for the fan thats actually causing it to run slightly hot...?
or
Gauge sensor thats reading wrong...?
or
Both... :cry:
Rishi
