replaceing the main oil seal help
gtirtimbo
I need to change front crankshaft oil seal (not Flywheel)
Is the seal the same as other SR20DET??
Mr Nissan does not know
Has any one changed theirs?
Does the timing chain need to be moved? etc
Can it be done with out the special tool which is pictured in the workshop manual (EM80 – EM90 around)?
Any help with a procedure would be great
thanks
Timbo
sypher
the seal doesn't actually fit onto the oil pump lika a ford etc, as the timing chain is a wet item it fits onto the outer casing of the pump and seals against the crank pulley ( machined / shiny ) inner surface. you'll see what i mean when you take it off........... no timing or oil pump removal / adjustment necessary
gtirtimbo
thanks sypher
I've getting a gear puller this weekend
I'm having trouble cracking the crank pulley nut
I don't have access to air tools
So I've been told to put a breaker bar on the crank pulley nut and wedge
Somewhere and turn engine over!! :?
Is this the only way?
Thanks
Timbo
That sounds decidely dicey to me :? I would get the breaker bar, lean on it and hit it with a mallet. The shock from the mallet has a much greater chance of freeing it off and, won't destroy the car or shear off the crank shaft. This will have a similar effect to cranking the car over but, is much more controllable.
Try to put some penetrating oil on the nut and perciveer. Should free off fairly (immortal last words :roll: ) easily :wink:
Paul
I saw someone say that yesterday on another forum. It ain't something I'd try tho. You might need to lock the crank to stop it rotating. Sometimes this can be done by putting the car in gear and have someone apply the brakes.
gtirtimbo
Thanks Guys
I tried the turn the engine over with the dizzy disconnected from the coil
But don't work, not enough power or torque from the starter motor
So I got the misses to hold the brakes pedal to the floor
With 5th gear engaged
And POP - the nuts loss :D
Easy as
Thanks again Fast Guy and Paul
Timbo
