Quick one on PCV valve
keastygtir
Just some advice please
I have removed my PCV valve today. I bought a kit from steve pudney with the caps and bung etc. When looking at it i decided I might aswell junk all those little pipes and so have only the four throttle body nipples to block.
Now steves kit comes with 8 bungs which I assume you use the extra ones to cap off the pipes if you leave them in situ. As I have removed them I dont need them. Have I done wrong?
Ta
The 8 caps that are supplied are so you can replace the 4 existing ones that are on already, which you can use for balanceing the throttle bodies :D.
The small wee black caps are for covering the balancing screws. :)
Hope this helps you out
Davie
Good luck balancing the carbs on a fuel injected engine! :lol:
I know what you mean really - balancing the throttle bodies, which most people will never attempt.
