Plug leads coming loose
W
willson
Ive been having an intermitant misfire. everytime i check it out the plug leads are bouncing round. I ve changed the leads and its still happening. Ive put a bit of silicon rubber to try and stop it happening. Anyone else had similar experience problems. Or any other suggestions to cure this irritating problem :x
W
WoOsH
I noticed this today. mine hadnt started to misfire tho it had deffo worked its way loose
kingy
have a look down the lead and you will see a split metal ring (looks like)
whip a plug out and push it in the end of the plug lead, if you don't feal or hear a click when you push the plug into the lead then you will need to get some plyers (sp) look up the lead and get the plyers around the area that the metal ring is and gently squeeze the ring shut a little now try the plug in the lead if it is still not a clicky fit repeat the steps. Don't squeeze to hard though and don't make it to tight a fit or you wont get your plug out without breaking the end of the lead off. :wink:
This should sort you prob mate :D
