Open door light
K
kerry
The one thats on the dash that tells you whether there is a door open or not
well its constantly lit up even though all the doors are shut and its winding my alarm up aswell
any suggestions?
Rishi
Still waiting on some shims!
If its winding up your alarm then either the sensors aren't picking up a locked door or one of your hinges could be bent again meaning that your door is not holding in the correct possition...
Check everything... Turn the alarm on and then press against the doors, boot and bonnet... the ones thats causing the prob sill set of the alarm when you press against it...
If its a Clifford then its more than likely to be the bonnet switch... It can fail after a while from the force of the bonnet closing on the switch...
Rishi
paz
The boot definately does, not sure about the bonnet. I only know because I've left it open a couple of times myself, hence the question :oops: :lol:
Paz
Stevo
i had this ur interior light bulb has blowen mate so circuit is broken.
switch ur interior light switch to off and the red door light on dash will go out.
