missing
gtir bean
what would cause this when under full load?you feel it missing and pop out the exhaust.i have put the timing back to 18degrees too see if that helps and will get a new dizzy cap next week.i just done the rotor arm so it should all be ok then as the leads are nearly new.would a worn dizzy cap cause this?
Dooie Pop Pop
ok im pi55ed so im gonna moan :lol:
POST IN FOOKING 'PROBLEMS' IF YOU HAVE A FOOKING 'PROBLEM!!' :roll: :lol:
check your earths/fuel pump/fault codes/fueling/vaccum hoses AND failing that walk away for a bit, i always find that helps :wink:
stu
