Low Oil pressure after rebuild
Thor
Hi,
i still have a problem with the oil pressure. Few months ago i had low oil pressure at all revs.
Then i had put the engine out of the car and rebuild them. I had fit another block with new Mahle pistons, acl bearings and a new oil pump.
After rebuild the oil pressure is same as before! But where is the issue???
Maybe oil pressure sender???
Thanks
Sascha
whytie
I'd check sender and also check the sump isn't dented, the slightest dent at the pickup will give you issues
