Hi spec disc conversion
thehybridsnail
Hi guys,
i have just purchased a hi-spec big disc kit. I am in the process of fitting it, but the lowe bolt that attches the new mounting bracker it to bigfor the original hole. Any ideas?? Do i have to drill the original hole out?? Thanks
thehybridsnail
There are two bolts that should go through the bracket on the hub, and attach the new bracket. The bolts screw into the new bracket, but don't fit through the bracket in the hub. I am crap at explaining this. Hope you get the jist of it. Cheers
johnny gtir
I dont quiet understand is it not a case of using existing bolts to bolt bracket to hub and the new bolts bolt caliper to bracket. I am not saying it is this just trying to help.
