Front trim removal..Help!
6
6Miester
:D As the title really-for some reason :roll: the trim that runs under the headlights and grille has become really stone chipped.
Anyway, i fancy giving it a quick re-spray but am having problems removing it.
So far i have worked out that it is held in place by a centre bolt which can be 'got at' after taking the grille of.
What holds the two ends on? And whats the easiest way of getting at them?
While im at it-is the Haynes manual any good for the Sunny/Pulsar?
Cheers :wink:
6
6Miester
andygtir said:
theres a bolt under each indicator :wink:
:D Cheers, do you just need to take the indicators out? They pull out on most cars iirc :wink:
yes, take them out, theres a screw on top of headlight then poppers in the wing, youy will then see the bolt, 10mm iirc
6
6Miester
:wink: Thanks.
