Fitting the silver look bulbs in the indicators???
jaigtir
What is the best way to remove the orange parts from the front and rear lights. shall i just heat it and take the front off, or are there any easier ways?
thanks
either put them in oven for a min then take the front lens off or from the bck pop it into the lens and shatter it with a pair of long nose pliers and empty contents
Ash
I used long nosed pliers to break up the front one, and a drill bit in a T-piece handle to crack the rear ones, then used pliers to break them out after that.
best piece of advice is take it slowly, if something isn't working, try another method.
jaigtir
oh bugger, as predicted, when i have a go at something, it comes off worse than wehn i started, the fronts were fine, but when i tried to take the rear lens off, i cracked it, bugger :evil: .
Off to the scrapyard i go :?
jaigtir
cheers guys for you help, got all the orange bits out, took your advice ash, and used the drill bit. Just got to replace the rear drivers side light now, due to my stupidity earlier, lol.
Looks good though 8)
