Rishi
Still waiting on some shims!
S14 SR20DET: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing,
62 trim 53.8mm T-25 turbine. .64 A/R turbine housing. Ball bearing center section.
S15 SR20DET: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing with Inco turbine wheel, cast divider wall between turbine discharge and wastegate. Ball bearing center section.
Pulsar GTi-R: T-28, 60 trim 60 mm BCI-1 compressor in standard T-3 housing. 79 trim 53.8mm Inco T-250 turbine wheel .86 A/R turbine housing. Journal bearings.
The GT 28R is 60mm 60 trim 0.6A/R compressor with 62 trim 0.64 a/r turbine
