E-Manage Harness ??
tee
i've had a look on herer but can't seem to find the info im after.
what i want to know is if there is a plug and play harness for the R to run with the Greddy Emanage, and if there is where is the cheapest place to buy it from?
or is it a case of buying the 200sx harness and modifying it to fit?
many thanks
tee
i ahve got the injector and ignition harnesses already, but thought there was another to plug into the ecu.
so does it still need hardwiring into the ECU?
Fusion Ed
It is true that you can use the harness from the 200sx and make a few changes to suit the R for almost plug and play. I think these adaptors are something in the region of £100-150.
Fusion Ed
That's the best bet really. If your going to do it your self try to keep the wires short and solder all connections. Its much more reliable that way than by having crimps etc.
Ed
