cusco 4 point lower brace and mongoose???
str_motorsport
wanted to fit a whiteline lower brace, but unfortunatly i will have to wait too much for it so i will probably fit a cusco one.
only concern is if it will fit with my goose downpipe.
i know the whiteline will fit, but what about the cusco one?anyone has one and a goose?
thanks
David
str_motorsport
thanks mate, and do you have any problems with the goose touching the brace?
if it is ok i will but the cusco one
RishiGTiR said:
vpulsar said:
Mines fine mate I have an inch or two :wink: 8) .
rob
Is that all... :shock: Unlucky!... :p
:lol: :lol: :lol:
Your bird was happy enough with it while you where away buddy 8) :lol: :wink: .
rob
C
Crazy
When I had my Cusco 2 point brace on it rattled really bad on idle and eventually caused my manifold gasket to start blowing :roll:
I am also on the look out for a Whiteline lower brace :wink:
str_motorsport
so it is better to wait for the whiteline one?
any other info?
All I can tell you mate is that mine is fine and has been on for 3 years now :wink: , You can jiggle the front pipe around a little or even heat it up and bend it out the way a little :D .
rob
C
Crazy
The problem with the Cusco is it sometimes catches the exhaust and the Whiteline one is supposed to catch the floor sometimes if your GTIR is lowered. :roll:
Non of the places I went to would bend it out the way a little evn if I payed. :roll:
So the choice is yours mate :wink:
str_motorsport
does anybody has a picture of the lower bar fitted with a goose?
and for gtound clearance?
that would help a lot....
as for the design, which is better?the whiteline or the cusco one?
GAZ P
I've got a Goose & Cusco 4 point lower brace the pipe clears the Goose by a good 50mm.Even with the 80mm drop on my car the brace boesn't catch any of the speed humps around where I live.
Dooie Pop Pop
.....lucky you :wink: what kind of mounts have you got? i had less than inch on mine. i guess there' s a fair ammout of differences between mongoose mounting brackets then. 50mm does sound a lot though :? does it rattle on the heatshield?
i have speed mountains where i live btw :wink: :lol:
stu
C
Crazy
.....lucky you what kind of mounts have you got?
Just what I was thinking myself :wink:
But there also could be another reason.......................afterdoing bit of research there seems to be 3 different Cusco lower Braces :shock:
Yes 3 :wink:
Cusco 2-Point Brace :!: http://www.gtiroz.net/gallery/albun63/aai
Cusco 4-Point Brace :!: http://www.gtiroz.net/gallery/albun63/aaj
Cusco 4-Point Brace v2 :!: http://www.gtiroz.net/gallery/albun63/R_cuscobracev2
So this could be why some rattle on the exhaust and some do not :wink:
Now all we have to do is find out which one does not :p
Who wants to be the GTiR ginuea pig :lol:
Yo vpulsar............................you on line :lol: :wink: :p
GAZ P
Mine is a 4 point one with a fixing bracket through each rear wishbone mount then a mounting plate onto the ARB retaining block.Came from Japan only know its a GTI-R fit after translating the web page, looks like the standard 4 point one.
C
Crazy
JIC Lower Arm Bar I
JIC also do a lower 2 point brace for the GTiR :wink:
Anyone got one or tried one???
