creeking when braking
I've not been on the forums for a while as I've not been using my R, but I thought I would post to see if anyone has any ideas for this.
I had a banging noise when cornering before which turned out just to be a loose wheel bearing so was easily fixed. However since then when braking I get a creeking noise from the passenger rear wheel.
I've stripped the brakes down that side and everything looks fine, the pads are new, the disks old but ok. Any idea what could be causing it? I guess the disk could be warped so I might put a new set on after xmas, maybe greese up the caliper sliders some more?
Anyone else has this problem?
