Crank Pulley?
Shaun
:D Hi guy's,has the crank pulley got to be off a sr20det or can i get one off an sr20de :?: I know its been asked before,but i've done a search and no one answered the question :!: :wink:
Thanks.
Shaun.
stevepudney
GTiROC CHAIRMAN
Yup, deffo spefic to the gtir SR20DET, if you need a replacement then there about £250 from Nissan or you could get the bling alloy set from Forge :wink:
Shaun
Your spot on Steve,£250 from Nissan :shock: :shock: :shock: Called them this morning :wink: Managed to get one from a breakers in London,should be here by Wednesday :D
stevepudney
GTiROC CHAIRMAN
Cool nice one.
The problem with the OEM one as you probally already know is it comes in 2 parts, with an inner and outer ring on the main pulley.
The problem is the 2 parts eventually start to seperate and the outer part tends to start to move round the inner part, this causes all sorts of problems as the OEM timing marks are on the outer ring.
You just need to make sure you get a good un, good luck anyway.
:wink:
