gtirx2
Ok my R is driving me nuts and the first time in 5 years i have nearly had enough:evil:
From my other thread where i throw 5 rockers after the engine had only behine in a couple of weeks i then fully stripped the thing changed the head,oil pump and a few other bits and gave it a good check over and it all seemed fine.
So off i go up the road driving like a granny because i did not want it to breck again,i pull over to find i have a oil leek from the crank shaft pulley seal which i did not replace when i changed the oil pump,no problem i thought so i check the oil and head back home slowly.
I get half way home and there is the worst rattle vibrating noise coming from the clutch on deacceleration you have ever heared so i creep back home hopeing its alright:shock:
Get back and find the crank pulley has come loose:sad: so i thought that was the rattle.So i take the pulley off praying it has not damaged the crank [which it has not crank looks fine] thinking that was funny for that to fall off as i can remember even double checking that it was tight and torqued up when i put it on:?
I put the pulley back on thinking i have it sorted[thank god i don't have to take the engine back out]then to my horrer start it back up and the rattle is still there :evil:
Turns out the flywheel has come loose as well,wtf:evil: :evil: :evil: and is rattling about on the bolts:sad:
What i am asking is do you guys have any ideas what could have caused this?the flywheel has behine on this engine for ages know with all the bolts lock tighted when it was first torqued up,it has behine fine for about 4000++ miles with no problem at all:? and for the crank pulley to come loose as well it is proper stressing me as i don't understand what or why this has happend?
The only thing that felt different when i put it back together this time was the clutch pedal felt a bit lighter that normal but i put that down to me using my helix 4 paddle plate instead of the 3 paddle hks plate that the springs broke in?
Do you think that me using the helix plate with the hks clutch cover i use could of caused it to be out of balence and shook the flywheel and crank pulley bolts loose:?
Any opinions are welcome as i have not got a clue, and i don't think i can handle taking the engine out for a fouth time in 500 miles,god i am realy starting to hate my R
