Clutch bite point
keastygtir
Hi Guys
Tested moving the car tonight, the clutch engagement seems quite low to the floor. I have a new CC stage 3 clutch and re-inforced fork, new slave cylinder. I have bled the system.
I have also noticed the rod from the slave cylinder rattles against the bracket slightly when clutch is disengaged.
The clutch is clearing ok and I can select all gears. The bite point just seems low.
Any advice?
keastygtir
would it be normal to have to adjust the biting point moving from a standard clutch to am uprated one?
whytie
I've had to do it in the past from changing clutches. Worth trying it as it only takes a few mins
You're obviously better at it than I am. - Hours upside down with a spanner and needle-nose pliers slowly inching it around until I got it where I wanted it.
