Changing the wheel bearing
Is changing the wheel bearing a complicated procedure, or is it just a case of remove old one, fit new one?
Do I need any Heat or special tools?
Thanks
Dan
Nad
AFAIK the fronts have to be pressed in, and possibly the rears as well.
Nad
Tony
I`ve done the front and back bearings, piece of pi55.
as long as you`ve got a decent place to work on it,
just used a large hammer to knock the bearing out and in.
also the rear bearings are the same as the front, and are sold for less than the fronts :?:
I got mine from a local bearing supplier and paid £20, bearing in mind that you will have to get the seals from nissan, which are pennies.
Tony....
cheers lads, I can work on it in my garage.
Thanks
Dan
