Anyone with a Turbodynamics MD214?
skiddusmarkus
Are the actuator dimensions/rod length the same as standard?Is it the straight rod or bend rod type(assuming its straight, never seen the bent type).Am looking to get a stronger one from either Forge or Td and cannot check the one on the car atm as car won't start and its parked in my garage.
Cheers, Simon.
skiddusmarkus
I've now been offered a used bent bar one, tbh I haven't seen one of these on our turbos but Forge do list them.Which model are they for and anyone know if they can be used on standard turbos(hence mine if standard ones fit)?
stevepudney
GTiROC CHAIRMAN
Get a straight one off a used turbo from Bob or a new straight one from TD (Nothing wrong with getting a used one from superbob but I'd go with a new one as you should get new e-clips with that)
ive got stock ones but tbh you would be best off buying a new one (either forge or hks)
i made the mistake of fitting a s/h one on my car and shes not holding boost at top end on the dyno so wished i had bought a new one instead of being a tight fooker lol
