80mm Z32 AFM?
Mr GTiR
is this the correct one for our car which need a bigger AFM?
The details i have are: 80mm diameter air flow meter made by UNISIA JECS CORP JAPAN. It has a 3 pin plug socket on the side, and a pink label on the other side with the following numbers printed on it; top row 22680 31U00 A36-608 E60. Embossed on the lower level is 8521E.
Is this the correct one i need to buy?
Regards
Andy
Gainspeed
:? is mine not right then if its got a five pin plug?
and says 22680 02u00 a36-000 j60? underneath 9626a
bit concerned now!!
nismoboy
bit concerned now!!
thats the one i have not sure if it will work tho :?: it has 5 pins.
E
Edd
shut it sweeny that maf's going on a real car not a shiny sh*tty rust bucket with a f*cked engine :oops: :lol: :twisted:
Gainspeed
Ginga, did you mean the 3 pins off the skyline or the 5pins?
or does anybody know what the five pin ones are off? :?
Sweeny
I woz gonner say somethin along them lines, but we know how emotional mr chan can get, hes a big girl really.
Gainspeed
austingtir said:
z32 afms have 6 pins ABCDEF only 4 are used in the plug. BCDE
z32 afms have an orange sticker.
z32 afms are 80mm.
so what are the 5 pin ones with a green sticker :?
Mr GTiR
austingtir said:
Mr gtir im afraid you have a rb25det-vg30det airlfow meter hard luck.
good job i did not buy it then, i saw it on Ebay going cheap!
Which version of the Z32 AFM do i need then. The car will be around the 400bhp mark.
Would the Q45 be too much for my car?
GINGA
Any of the 80mm maf's should be fine its just a matter wire wiring them up correctly which shouldn't really be a problem as there normally just power,earth and signal to wire up
ashills
there is a difference in teh 80mm mafs some are better than other for higher bhp
i have maxxed my Z32 maf out and have to change over to map sensor at high revs when running more than 1.5-6 bar
this can probably be adjusted on power fcs just so fuel keeps rising on rpm or something like that
