3071r part number
GTIR-LOZ
hi i have now got my 3071r (i think) but just want to check the part number to make sure its correct, can someone post up their number off the metal plaque, i assume this is the part number?
carlengerer
700177-0003 (cropped T28) GT3071R-WG
700177-0023 - T3 version.
that's what number you should have on the core of the turbo.
(cut and paste below)
Garrett family of GT30 UHP Turbine based turbos , aplication HKS / Garrett .
Next time you say you have a "GT30R" it could be any of these or maybe others .
Unit part no , CHRA , Note no .
700382-0001 , 700177-0001 , 01) Unknown but maybe 2835 48T , 84T Turb
700382-0002 , 700177-0002 , 02) 2835 52T , 56.6mm 84T Turbine .
700382-0003 , 700177-0003 , 03) 2835 56T , 56.6mm 84T with .64 a/r .
700382-0004 , 700177-0004 , 04) 2835 56T , 56.6mm 90T Turbine .
700382-0005 , 700177-0001 , 05) Unknown .
700382-0006 , 700177-0002 , 06) 2835 52T , 56.6mm 84T Turbine .
700382-0007 , 700177-0003 , 07) 2835 56T , 56.6mm 84T with .86 a/r .
700382-0008 , 700177-0005 , 08) Unknown , suspect GT3037 48T .
700382-0009 , 700177-0006 , 09) GT3037 (GT30R) 52T , 60.1mm 84T Turbine
700382-0010 , 700177-0006 , 10) GT3037 (GT30R) 52T , 60.1mm 84T Turbine
700382-0011 , 700177-0007 , 11) GT3037 (GT30R) 56T , 60.1mm 84T Turbine
700382-0012 , 700177-0007 , 12) GT3037 (GT30R) 56T , 60.1mm 84T Turbine
700382-0013 , 700177-0008 , 13) Unknown
700382-0014 , 700177-0009 , 14) GT3040 , 50T GT40 Comp , GT30 Turbine .
700382-0015 , 700177-0008 , 15) Unknown
700382-0016 , 700177-0009 , 16) GT3040 50T
700382-0017 , 700177-0001 , 17) Unknown .
700382-0018 , 700177-0002 , 18) 2835 52T , 56.6mm 84T turbine .
700382-0019 , 700177-0003 , 19) 2835 56T , 56.6mm 84T Turbine .
700382-0020 , 700177-0004 , 20) 2835 56T , 56.6mm 90T Turbine
700382-0021 , 700177-0004 , 21) 2835 56T , 56.6mm 90T Turbine
700382-0022 , 700177-0008 , 22) Unknown
700382-0023 , 700177-0009 , 23) GT3040 50T (.70a/r) , 1.12 Turb a/r .
700382-0024 , 700177-0003 , 24) 2835 56T , 56.6mm 84T Turbine .
Real Garrett GT3071R
CHRA 700177-0023 - GT30 Turbine with 71.1mm 56T GT35 Compressor .
TO4S compressor Type GT30 Based BB Turbos .
CHRA
700177-0010 , 56.6mm 84T Turbine , TO4S 48T
700177-0011 , 56,6mm 90T Turbine , TO4S 52T
700177-0012 , GT30 84T Turbine ....., TO4S 56T
700177-0015 , GT30 84T Turbine ....., TO4S 56T
700177-0017 , GT30 84T Turbine ....., TO4S 52T
Garrett GT3040 56T
CHRA
700177-0014 , GT30 84T Turbine ....., GT40 82mm 56T Compressor .
Garrett GT 3082 BB .....
Not sure about this one , was once shown a 7/14 blade compressor "equivalent" of a GT3040R so could not be GT40 compressor .
Turbo , CHRA , Turbine housing A/R .
714569-0001 , 700177-0018 1.06
714569-0002 , 700177-0018 0.82
714569-0003 , 700177-0018 0.63
Do not confuse this one with 714568-0001/2/3 which is the GT3540R series and uses CHRA no 706451-0005
Where there are repeats in CHRA numbers mostly its the compressor and housing A/R's/type ie GT28 or GT30 that differ and this shows as a different assembly number .
Feel free to add or challenge the numbers as different lists often have conflicting numbers .
Cheers A .
Turbine housing breakdown to come plus specs of Garrett "GT3071R WG" and the HKS GT3240 if I can find them .
Continued :
HKS exhaust housings to suit the 56.6mm 84T Turbine GT2835 series
T28 Flange . Integral Wastegate in .64 and .86 a/r .
T3 Flange . Integral Wastegate GT Pro S style in .68 and .87 a/r .
External Wastegate in .61 .73 .87 1.01 and 1.12 a/r .
HKS exhaust housings to suit the 56.6mm 90T Turbine GT2835 series .
T28 Flange . Integral Wastegate in .86 a/r only .
HKS exhaust housing to suit 60mm GT30 turbines ie all GT3037 and GT3040 , also Garrett GT30R and GT3071R 700177-0023 CHRA .
T28 Flange . External wastegate in .61 .73 .87 1.01 and 1.12 a/r .
T 3 Flange . Integral Wastegate GT Pro S style in .68 and .87 a/r .
T3 Flange . Garrett make ext gate versions in .63 .82 and 1.06 a/r .
GTIR-LOZ
i have part number
700382-5020
above that it says KIM 024165
so is this not the correct turbo? as on garrett website it says
GT30
GT3071R
GT3071R - 700382-3
GT3071R - 700382-20
GT3076R - 700382-12
it is definate a t25/28 housing with the 86 ar exhaust housing
can anyone read off their part number from their actual housing to double check
carlengerer
GTIR-LOZ said:
i have part number
700382-5020
GT30
GT3071R
GT3071R - 700382-3
GT3071R - 700382-20
GT3076R - 700382-12
I think your right, I quoted you the CHRA part number, you have the unit number.
