Hi All,
Recently did a test and was getting fault codes 21 and 34. Changed the det sensor replaced yesterday and after resetting the fault check it appears this has fixed the fault code 34 problem.
Code 21 is still with me however :roll:
Having done a search, I know this means a fault in the ignition signal circuit, and that I should check the 'harness and connector' and power transistor unit.
BUT I can't find anything recent that seems a simple step-by-step approach to resolving this problem. Can any of you helpful people out there help me out?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
