timing chain
91_GTi-R
if the timing chain is a bit loose at the top between the cams does this mean that its time for a new chain or that the tensioner is no good?? and how big of a job is it to change the chain?
thanks alex
Bart GTI-R
Not too hard a job, Install it with the clip holding the piston in, then when rotating the enigne will release this clip and it will pop out & tension itself.
theres nothing wrong with it matey!
when the engine stops (turned off) there is always a bit of play between the 2 sprockets as its off load and wont stop on top of compression stroke.
if you put a spanner on the c/s pulley bolt and turn the engine clockwise a little, then the play will dissapear.
no need to touch anything;-)
