Rear subframe bushes.
dencon
Just fitted vss irvines rear subframe bushes to my new build, but in the box are four large washers. Can anyone tell me if these go on the top or under the bush. Martyn away for a few days, and I would like to bolt it back up. cheers den.
dencon
Still waiting for some one to help me position these large washers. They are about 3" in diameter. What is foxing me is the fact that the hole is large enough to go to the top
of bolt, which means that if fitted on bottom there is a lot of clearance around bolt. anyone anywhere know? thanks den.
PUL54R
I would think that the washer would fit underneath the bush, otherwise if you were to jack the back of the car up the head of the bolt would start to pull through the bush.
