overboosting - cause?
D
DodgeT
since had clutch changed yesterday, the cars overboosting. not sure what to as i havent fitted my autometer gauge yet, & its just going off the std gauge.
i have checked the 2 pipes which fit onto the intercooler & they are in place. everything around the dump valve also looks ok, & the hoses from the actuator look ok.
are there any other pipes, connections, anything what would cause the car to overboost???
Shaun
:D Have you got a frontmount or top mount intercooler :?: If you have a top mount,see if the actuator pipes are still connected to the intercooler,if you have a look at the plenum,follow the main boost pipe back to the intercooler,look to the left of it and you will see a small metal tube,there should be a vacum hose from this tube to the plenum,also if you look above where the standard dumpvalve is located under the intercooler the other end of the metal tube comes out next to the gearbox breather and this should be attached to the boost solenoid :!:
Hope this helps :!:
