seanleed
boohoo!!!
. Fitted my new turbo on Saturday, car started fine, idled fine, oil temp and pressure fine, coolant temp fine. Turned boost controller down to .5 bar and went for a drive around the town- all fine. Went out of town and as the turbo started to make boost I noticed a wee bit of smoke out the back, then loads of smoke :shock: , pulled over and noticed smoke coming from the front of the car, so popped the bonnet and had a look; smoke was coming from below car so got down and saw that the exhaust was covered in oil. The oil was dripping from the top of the oil return pipe, so took car home and went away for the day. Had a good look on Monday and saw that the oil return pipe was kinked, ended up ordering a hydraulic pipe to replace the standard return pipe and fitting into the block which I got yesterday and fitted last night (not an easy job :twisted: ) Took the car out today and I've still got smoke coming out as I start to make boost and for ages after I take my foot off the pedal
, car is now back on the drive. I've taken the hoses off the intercooler and there is no oil inside them and none around the dump valve. What I'm wondering is: when the return pipe was kinked would the build up of oil pressure in the turbo make the seals leak just on the impeller side? and is the oil just going through the seal at that side and out the exhaust :? The turbo's a T28 roller bearing. There is no smoke at idle or when revved up a bit, I didn't even get above .2 bar when I took it out 'cos I was trying to be gentle with everything :roll: I was soooooooooooooooooooooo looking forward to getting out in it again
Sorry about the long post, thought I'd try and include as much info about the prob as I could.
