Greddy profec B spec II settings to run factory boost
paz
Hi All,
I want to leave the lo boost setting on my greddy unit at standard boost until I can get it mapped properly.
Can anyone advise the settings that I need to use. Is it as simple as just turning the gain down to 0% or do I have to fiddle with the other settings too?
Cheers for your help
paz
geoff pine
reading from the instruction manual page 42 to turn boost controler off hold down the select switch for 2 seconds .
R
riske
or just have the low setting at 0 on all except the limit warning otherwise that will get annoying.
set gain 0
gain 0
R
riske
yeah it will store the same settings as before if you turn it off so dont worry. As geoff says hold it down and you will know when its off. Also if your set gain setting is set to standard ie 0.7 that will also make the car boost to standard, mind you you will have to pop it back up once mapped but your mapper will do that.
Thanks for the pic mine is an older version sorry i can't help. I did manage to find a manual for mine online though, maybe yours is on there too.
