Fog light relocation
LeeSmith
Has anyone relocated the fog light (on the import) into the rear cluster? if you have how did you do it?
GINGA
just locate the wire the works the inner brake lights on both clusters then cut the wire and insulate the loom end, then connect the original wire that went to the old fog light to the bulb end of the loom on both clusters[;)]
then your old inner brake lights will work as the fogs and the outer will work as brake lights and side lights should still work on both inner and outer[;)]
Wanted 16" raceline rl7's
Curtis
To make it easier I just connect up the drivers side inner brake light as a fog and remove the bulb from the passenger side! [;)]
Curtis
Before you criticise someone, you should walk a mile in their shoes.
That way, when you criticise them, you're a mile away and you have their shoes!
