door swap?
gtir bean
is it possible to put the window mechanism from a manual window into a door with an electric window?i found a nice clean door with no rust but would need to swap the internals.
It should be, assuming the bolt holes are the same, but you'd need to cut a hole in the door trim for the winder.
If the bolt holes are different get the dremmil out.
