Disassembly driveshaft
Hi guys..
I want remove the end of the front driveshaf to put it in the wheel hub and istall the wheels and I can move the car when I remove the engine..
sorry my english
help me please
thanks a lot
bye
do you mean you want to remove the cv joint from the shaft?
if so then just get a big hammer (preferably copper or hide) and remove the rubber boot and simply just knock the end / joint off by hitting it and holding the shaft at the same time with your other hand!
here you go, hit the cv joint where either of the two arrows are pointing. hold the joint straight when you hit it and give it one sharp wallop and it will come off
Mr GTiR
Another way is to put the shaft in a vice and pull the end off. I've taken many drive shaft out in the past and after a quick tug on the shaft it's just popped out in my hand. Btw, the method with the hammer is the best way of doing it.
not exit not exit and not exit..
I have tryed all your method but not exit..
I hate driveshaft..
if I don't pull out the joint,I can't remove the engine from the car:(
davey red.r
its got to come out!
this is getting me mad now:lol:
give it a wallop,i iknow sometimes they can be a bit of a tw*t to get off, but all come off eventually.
davey;-)
vss irvine
yes put the driveshaft in the vice,
remove the cv boot(rubber)
hold the cv joint in you hand (inline with the shaft)
pull the cv joint away from the driveshaft(with your hand) and AT THE SAME TIME
hit the cv joint away from the shaft.
if it doesnt come off, hit it harder, or use a bigger hammer.
if it still doesnt come off, ill sell you some loose cv joints!
