det senser
Fire & skill
Vintage member
does anyone know how to physically test the det senser?
If I have the senser in my hand can i check it with a multimeter?
dave
yes use the service manual, its pretty simple, follow the instruccions to to check the continuity of the cables with a multimeter, then check voltage with a multimeter at the pin 27 and a good chassis ground but you will need to de-pin the white cable from the blue plug for be able to turn on the car and check voltage of the ECU, ecu should give 3.xx volts... and that it...
just check the continuity of the cables and if the ECU give 3.xx volts, if continuity exits and ecu give the right voltage of 3.xx them go a head and buy a new knock sensor part number: 22060-30P00, its basically generic or quite common in many nissans.
