Cusco Pillow Ball top mounts
I need to dial out some negative camber and I'm after these Cusco items.
How much are they and where can I get them from?
I did try a search on here and it came up with www.checkerflag.co.jp, but can't find them on there
Sirnixalot
you can get them from checker, thats where i bought mine.
Just email and ask them. When i got them they were the following
1) Cusco Upper Front Pillow Ball Mounts;
Adjustable type; 18,700 yen
2) Cusco Upper Rear Pillow Ball Mounts;
Fixed type; 18,700 yen
srbpower
Cusco :roll: Post in our section dude :)
We've got massive cusco stock on route :)
Si :)
The rear ones dont appear to fit standard shocks :( My cup and mount were spot welded together and i didn't fancy drilling them apart to discover that it still wouldn't work.
I think Skiddus gave up on them aswell
Mine are still currently sat in there box in my bedroom :(
Sirnixalot
you have to seperate your standard rear mounts. Thats what i did and they fit fine. 8)
Nix.
Are you still on standard shocks then ? i guess you are.
I was looking at mine and smacked them about abit to see if they'd come apart but they didn't :) . Guessed they'd need the welds drilling out. Wanted to know if anyone else had done it first though before ending up with a pile of bits. Put up a post about fitting them but got no answers, they've been sat in their box for 8 months :oops:
If you're telling me that all i need to do is drill out the welds and lose the standard mount, using the cusco in its place you've helped me find this weekends job.
srbpower
Shaun said:
:D I've got TEIN top mounts from HI-TEC £230 all in :!:
If that was for all 4 then that's a good price.
If that was for a pair, then that's loads!
Dan
Sirnixalot
correct.
Dril those 3 welds out on each upper mount and use the lower bit with the cusco mount and you are good to go. Ive got Nismo shocks...they are standard replacments.
Are they OK, Someone I was talking to said that they had trouble with the 4 hex bolts moving slightly in the slot? Have you had any probs?
Cool :) How much for a pair of front top mounts, and when will they be in stock?
Sirnixalot
you have to grind away a bit the hole that the mount pop up t hrough. Ill post pictures of mine this weekend.
skiddusmarkus
Nikko-I think yours are differnet though.Ours are adjustable for camber whereas IIRC yours are just rose jointed.Best clarify this before he mullers his suspension.
Sirnixalot
yes true...are youre rears adjustable or solid Kerion?
What i stated works on the solid rears.
So does that mean you can make the camber adjustable ones fit standard suspension then?
Sirnixalot
not sure......i suppose i could check if no one else can....(still sore from gym)
Nix, like skiddus mine are adjustable, have you got a picture of yours ?
Could probably tell from that if they'd fit the same, failing that i suppose i could get my hands on an old mount from somewhere and bugger that one up first :)
Sirnixalot
ive got a pic but my image hosting site might be being dumb....whoa they are actually working!
skiddusmarkus
Well I had the whole ADR rally team working on my car trying to make it fit 8) -was surrounded by Evos and a Focus with wheels worth more than my car(about as close as a GTiR gets to a rally these days :lol: )and they said it wouldn't fit properly.The problem was the damper would rotate as tit wouldn't be held properly.
